JeffR Posted June 17, 2015 Share Posted June 17, 2015 So the lower hinge on the , still immobile, family hack was getting a wee bit rattly. It's a pin thinks I, just knock it out drill a slightly bigger hole and replace. Wanna bet? I don't know what LR used as a pin, but 1: belting it with a 4lb hammer and heat won't shift it 2: the local garages 15 ton press won't shift it 3: the steel appears to have a shore hardness value greater than bloody diamond so you can't drill the bugger out (need some new cobalt drills now) Anyone done this successfully, if so how? Quote Link to comment Share on other sites More sharing options...
