Andy A Posted July 13, 2015 Share Posted July 13, 2015 In the process of building up my series I'm trying to build up my hand brake linkage I've got a pull off spring but I can't quite work out how it all fits together Lever pulls the brake on,but it doesn't release,I have to push the rod down manually to release Any body got a picture of how it all goes together Car was bought already dismantled so I'm piecing it together as I go along Quote Link to comment Share on other sites More sharing options...
Serious Series Posted July 16, 2015 Share Posted July 16, 2015 Should be a washer with a lug and hole in it on one of the gearbox mounting bracket bolts hook goes from there to similar washer on bottom of operating rod Quote Link to comment Share on other sites More sharing options...
Andy A Posted July 16, 2015 Author Share Posted July 16, 2015 Thanks for reply All sorted now Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 18, 2015 Share Posted July 18, 2015 The bottom of the vertical link should ahve a locknut where it meets the clevis fork. Bteween nut and fork should be a tear-drop shaped washer with a small hole in the tip. There should be a similar tab on one of the gear box mounting studs where the transmission bracket is attached tot he trnasfer box. A strong coil spring hooks into each tab to pull the vertical link straight down. Quote Link to comment Share on other sites More sharing options...
