wolfgang90 Posted July 20, 2015 Share Posted July 20, 2015 Does anyone know what the threads are coming off the power steering pump high side? I'd like to tap into that for slow running hydraulics, but I can't find anything in the rave about what the threads are.... Quote Link to comment Share on other sites More sharing options...
sierrafery Posted July 20, 2015 Share Posted July 20, 2015 check this out, maybe it helps http://www.landroversonly.com/forums/f40/power-steering-pump-high-pressure-pipe-bolt-size-39188/ , though here is stated 17mm http://forums.lr4x4.com/index.php?showtopic=70152&p=599906 Quote Link to comment Share on other sites More sharing options...
ejparrott Posted July 20, 2015 Share Posted July 20, 2015 I've got a spare pump at work as I'm also after fittings. My 109 currently has a standard hydraulic hose fitting on it nothing special. Unfortunately I didn't keep a record of what it was and I want to change the setup now! Quote Link to comment Share on other sites More sharing options...
