dave88sw Posted August 9, 2015 Share Posted August 9, 2015 Hi, Does anybody know a source of a straight through centre pipe for a 3.9? Island 4x4 used to do them but they dont seem to list them anymore. Alternatively, has anyone got a suggestion for a better system? I'd like to make a bit more of the V8 noise without it being too intrusive to drive every day if you see what i mean. The standard system is just a little subdued. Thanks Dave Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted August 9, 2015 Share Posted August 9, 2015 Straight through centre pipe does make it quite loud, so it depends how much you want to put up with as a daily driver. Personally I would find it a bit too much, was fine on the rally car, though. Terrafirma do one. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 10, 2015 Share Posted August 10, 2015 I am having similar thoughts to you. My 3.9 is in a 110, and with all silencing provided by Tdci pipes, it's not sounding very V8-like. Downpipes are Ø2", and main pipes are Ø2.5". The main silencer is colossal! My thoughts regarding experimenting have been: Unbolt the rear section with its small silencer, and see what sort of sound I get. Replace centre section with a straight through pipe sold by Paddocks, thus leaving the quite small rear silencer, and see what sort of sound I get. This of course may waste precious £ on something that may end up being a bad idea. That said, it could be a good basis for adding my own choice of silencer Other thoughts - I recently saw a V8 challenge truck with quite a short system, and just a single, modest sized box that gives an idle sound that is pretty discreet, but definitely a V8. When worked harder, it sounds lovely without being obnoxious or OTT. Unfortunately I didn't get to ask the owner what the spec was of the silencer. There are many types of exhaust silencer, and I'm still reading up on each. Anyway, I think my objective will be reached by using the correct type and size of silencer, rather than removing one or more altogether. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted August 10, 2015 Author Share Posted August 10, 2015 Thanks guys, something to think about. I hear what you're saying about total removal of the centre box, i suppose i don't really want it to be intrusive, i don't often do long journeys in it but i don't want to make it unbearable if i do. If i could weld and had some old pipes about i would have a go at removing/swapping silencers and see what i get. The rear box did rot away and i pulled it off a while back (since been replaced with another standard section with silencer) but i can't honestly say it made a difference to the noise when it was missing altogether!! I need to replace the centre section regardless as it's full of bits of the old cats!! so i could try a straight through and see what it's like, if not i haven't lost too much money. Cheers Quote Link to comment Share on other sites More sharing options...
