jflandrvr Posted October 12, 2015 Share Posted October 12, 2015 Replaced the Shuttle Valve on my '00 D2 this past weekend. Drove it all weekend with no "3 Amigo" lights appearing. Was on my 1 1/2 hr drive back home running between 65-70 mph and at about 60 miles into the trip the alarm chimed, and up comes the 3 Amigos. Now, when you turn the engine off and then back on they stay off as long as you are running low speed. Any 60 mph drive over 10 minutes, they will reappear. I plan on getting the codes read, but just wondering if anyone else has had this problem before? Quote Link to comment Share on other sites More sharing options...
robertspark Posted October 12, 2015 Share Posted October 12, 2015 If you do a search for wabco and amigo or amigos I've posted the full manuals with the flashing code lights before on here Edit: Post added here .... (had the time now to find it) Quote Link to comment Share on other sites More sharing options...
sierrafery Posted October 13, 2015 Share Posted October 13, 2015 Hi, the D2 has a SLABS ECU and even if the ABS works like on a defender you can't make any blink tests on it ... if the fault code was SVS related but you only replaced the switch pack that's not enough, you have to do the wiring mod, explanation here https://www.landyzone.co.uk/land-rover/the-dreaded-three-amigos.284839/#post-3513501 Quote Link to comment Share on other sites More sharing options...
