Fast idling V8
I've got a bog standard 3.5 V8 running on SU carbs. I recently rebuilt the carbs with the full rebuild kit and set them up according to the official manual and it all starts and runs well except for one problem. After a long run the idle speed increases to about 1,200 rpm. If I turn the engine off for a minute and start it again it's fine. And it idles normally at all other times, it's only a problem after a long run on main roads/motorways.
It doesn't appear to be a sticking throttle as I've checked that both throttle levers are on the throttle stop screws . I put in new throttle disks and left the overrun valves in place so I guess it could be one or both of these sticking open.
Any carb gurus out there with some ideas of what could be causing this problem?
Thanks
