landroversforever Posted January 19, 2016 Share Posted January 19, 2016 The advantage of the air suspension coupled to the independent suspension means it lifts the diff as well. There are also lots of vulnerable bumpers/skirts to worry about Quote Link to comment Share on other sites More sharing options...
georgecorbett Posted January 19, 2016 Author Share Posted January 19, 2016 It depends on a lot of different things. What is the vehicle used for? what is the budget? to name a couple. Lifting it with HD springs will help the body roll potentially, but won't flex very well. I have it sorted now. The steering was 5 degrees out and now that it is correctly adjusted it handles a lot better on the road. Thanks for your advice. I go off roading and run on 265 insa turbos. With out a lift kit the wheels rub the arch's Quote Link to comment Share on other sites More sharing options...
