tony109 Posted January 17, 2016 Share Posted January 17, 2016 My old 2.25 diesel is on its last legs, burning oil, etc. So I've gone for the 5 bearing updated engine. Now am I right in thinking all the treads are metric on this engine? As its missing all the studs on the flywheel, the dipstick tube, manifold studs, engine mounts etc this is more of a mission than I thought, thinking I could simply swap the bits from my old 2.25 3 bearing. Theres 4 bolts instead of two holding the engine mount brackets, so were can I go for these parts.. Paddocks look good but am I right in thinking the engines all gone metric? Plus the crank shaft drive dog for the capstan winch will be missing... So its the studs and bolts I need, can anyone advise a source? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 17, 2016 Share Posted January 17, 2016 Have you had a look at the parts books? There are links in the tech archive to a few, they will list the bolt type next to the part number, normally. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted January 18, 2016 Share Posted January 18, 2016 Is the engine mounting not just a choice of two locations was on my 2.5 15J diesel which is the same design engine block. HNJ engineering do a metric drive dog bolt and drive piece. Quote Link to comment Share on other sites More sharing options...
tony109 Posted January 25, 2016 Author Share Posted January 25, 2016 Hi, thanks for the HNJ drive dog.. Not the same as the crank drive but the crankshaft bolt might be the answer. Its the bolt size for the engine mount bolts in the block Im stuck for. They're metric and probably the same size for the 2.5 and maybe 200 tdi? Quote Link to comment Share on other sites More sharing options...
