v8Dougie Posted February 19, 2016 Share Posted February 19, 2016 Hi all. My 2003 Disco is having a few occasional gearbox issues. So, sometimes, normally when cold, start the car, select drive but the car does not creep. To get it to engage you have to rev the engine hard, then it will drop in. Been doing this occasionally for a while, but now getting worse, more often and when it does drop in the gearbox now goes into limp mode (flashing green M & S lights on dash and flashing D). Turn engine off, start it again, and all is well. Gearbox drives otherwise as it should I think, only auto Disco 2 I have ever had, the gearbox is a bit lumpy and lazy in comparison to the super slick Disco 3 gearbox and my Saab 9-5 one but I assume that is correct as older technology. Fluid should be fine (I will check though) as the fluid was changed a couple of months back and no major leaks. Fluid was changed again a few weeks after as one of the cooler pipes blew. Anything else I could check? Battery is brand new as I have seen that as a cause in some other threads. At a bit of a loss really, so any help much appreciated. Quote Link to comment Share on other sites More sharing options...
BennehBoy Posted February 20, 2016 Share Posted February 20, 2016 Sounds like a valve block issue, usually caused by debris from a disintegrating clutch pack. Was the ATF dark at the first oil change? Was the problem there before the first change, these boxes are renowned for failing once fresh oil has been put in because it acts like a detergent and frees up any carp to float about. It's probably rebuild time. Quote Link to comment Share on other sites More sharing options...
discokev Posted February 20, 2016 Share Posted February 20, 2016 It sounds like the xyz switch ,look on eBay sure I've seen recons on there.A lot cheaper than new ones. Kev. Quote Link to comment Share on other sites More sharing options...
v8Dougie Posted February 21, 2016 Author Share Posted February 21, 2016 I like discokev's response better, no offence BennehBoy!! I haven't done many miles in the car since I have had it, bought it with a misfire so had the engine rebuilt. The guy I bought it off gave me a 25ltr barrel of ATF which he had done a gearbox change with. Perhaps the problem happened after that? It definitely happened before I had the oil changed, and before the cooler pipe popped, but it has definitely got worse. Could be as you say that the ATF has free'd up some crud. I didn't do the oil changes a garage did, they said the oil was quite fresh that came out. I'll have a look at the XYZ switch, but why would it engage gear with revving the engine? I have heard about starting it in neutral, then going to drive as it is Reverse which is where the problem is on the switch, other check is if the rear wiper comes on when the front are on and you select reverse. Strange thing is, I am sure it will always engage reverse, it is just forward gears it won't! Can't even check now as the car is back in the garage getting the starter motor changed and the post cat lambdas swapped over! Quote Link to comment Share on other sites More sharing options...
discokev Posted February 22, 2016 Share Posted February 22, 2016 This gearbox is electronic mechanical if the pair dont sink it goes into limp mode. Personal experience 2003 td5 auto first switch 30,000M second at 95,000M. Move stick slowly between D N R P see if the lights match stick position at the same time,if theres a delay its the switch. It mite clear if you move the stick back and forward quickly, ignition off. Short term only Quote Link to comment Share on other sites More sharing options...
v8Dougie Posted February 24, 2016 Author Share Posted February 24, 2016 If I ever get the car back from the garage then I will have a go at this. Went in last Friday for a replacement starter motor and Watts linkage changed, they keep finding knackered bushes at the back and ordering them one by one despite me telling them to just do the lot!! Grrr. Thanks for the suggestions though! Quote Link to comment Share on other sites More sharing options...
BennehBoy Posted February 25, 2016 Share Posted February 25, 2016 I'm in Huddersfield btw - if it does turn out to be a shagged box I've got a spare one sat in my shed that you can have a for a pittance. Not after big money I just want rid, I bought it for a transfer box it was coupled to. I've also got nanocom & lots of tools. Quote Link to comment Share on other sites More sharing options...
v8Dougie Posted February 29, 2016 Author Share Posted February 29, 2016 Thanks BennehBoy that is very kind. Have the car back but have a new issue to deal with first, leaking coolant pipe!! Will get back on this once this is fixed!! Quote Link to comment Share on other sites More sharing options...
