mcc1979ian Posted June 8, 2016 Share Posted June 8, 2016 Iv got a 4 bolt steering box which iv fitted to my 90 but it was originally in a 200tdi and now iv installed a 300tdi. Im lead to believe the fittings on a 300tdi are different. Would anyone know what i need to connect up to the 300tdi? Cheers Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 8, 2016 Share Posted June 8, 2016 As far as I know all 4 bolt boxes are the same with metric threads as does the 6 bolt. 3 bolt are imperial. But the 200/300 pumps are different wether the pipe work is at that end I don't know. Mike Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 8, 2016 Author Share Posted June 8, 2016 Its the end for the pump on the 300tdi im needing. The pipe bolts up but dosent go tight. Quote Link to comment Share on other sites More sharing options...
