gothbiker Posted December 6, 2016 Share Posted December 6, 2016 Hi I've a eBay egt gauge, I've drilled and tapped the manifold for the sensor and wired the gauge up, it lights up with the ignition, but doesn't move, I've replaced the sensor and it makes no difference, if there is no sensor it reads to the max and with one wired up it stays on the bottom? The sensor wires are white and blue the dial is red switched live black earth white and finally green ive emailed the seller and had nothing back Quote Link to comment Share on other sites More sharing options...
