moony123 Posted January 22, 2009 Share Posted January 22, 2009 i want to use the the discovery rad intercooler oil cooler, in my series 3 has any body got pics of how they have done it?plz dont really want to swap bits need to use what i have got. dont mind welding new brackets etc ive got the defender front so got quite alot of room cheers all Quote Link to comment Share on other sites More sharing options...
-xLr8r- Posted January 22, 2009 Share Posted January 22, 2009 here's my SIIa with 200Tdi , 200Tdi rad & oil cooler , & intercooler right up front Quote Link to comment Share on other sites More sharing options...
Timmy511 Posted January 22, 2009 Share Posted January 22, 2009 if youve got a defender front just mount it all as a defender with two brackets on the chassis and then two on the slam pannel. The metal cowl that holds the rad and intercooler will require the bottm pin mounts cutting down so that the cowl sits flush on the chassis mounts, and then add two pins for the top mounts to locate onto. Quote Link to comment Share on other sites More sharing options...
minivin Posted January 23, 2009 Share Posted January 23, 2009 I had looked into the option of removing the standard air filter mount in a series and locating it there, however if your willing to do some chopping to the facier you could mount it within on the port side and run the pipes ah la defender. I got an alloy oil cooler and mounted inside the from facier as follows: Corr that was a few years ago now Quote Link to comment Share on other sites More sharing options...
