Headlights not working as they should
The side lights work as they should, with a low current going through to the main head light, but when switch is in the dipped position I have sidelights only no dim headlight. But then, if you switch to main beam, then turn back to dipped they all work fine, till next time you use them.
I know there is a box somewhere that controls this low voltage to the headlight business, and am thinking that may be the problem.
Any thoughts..........
Where is this box of tricks..........
Thanks
Andy
