undred Posted July 20, 2014 Share Posted July 20, 2014 Hi, I have a 2006 Defender 130 which has recently become temperamental on starting. About 40% of the the time it starts fine while the remainder all you get when you turn the key is a soft click as if you have zero power in the battery. I normally reset the immobilizer and after 1 - 2 mins of turning the key the car seems to fire up no problem. The non starting is becoming more frequent, I have charged the battery and changed some of the fuses which needed doing. Any suggestions on how to resolve the problem would be really helpful. Quote Link to comment Share on other sites More sharing options...
diggervan Posted July 20, 2014 Share Posted July 20, 2014 Hi I would say you have an earth problem try putting a wire from starter body to battery neg. If that works clean up the original engine to chaise/engine to battery earths hope this helps Bob Quote Link to comment Share on other sites More sharing options...
cackshifter Posted July 21, 2014 Share Posted July 21, 2014 A friend had this happen with his TD5.It's the contacts in the solenoid, a weakness of the Denso starter. But you don't need to replace the starter, there are kits about to fix the contacts cheaply, eg http://www.ebay.co.uk/itm/Denso-Starter-Solenoid-Contact-Kit-Landrover-Defender-Discovery-TD5-JAPAN-/290972477946?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43bf4fa9fa there are others as well. I think you can do it with starter in situ, but we took it off so you can see what you are doing (sight that bad couldn't get heads far enough away to focus), and it's only another bolt or two to take it off. Worked perfectly after that, and still does. If you are stuck and it doesn't work trying giving the solenoid a tap. But the kit is the permanent (at least for a while) fix, Quote Link to comment Share on other sites More sharing options...
