mad_pete Posted June 20, 2016 Share Posted June 20, 2016 Got a second hand r380 seat box. Need to spray it orange. Is halfords paint match okay ? Should I underseal or sound proof line it while it's out ? Hammerite okay for the battery box ? Quote Link to comment Share on other sites More sharing options...
Blackfiesta123 Posted June 21, 2016 Share Posted June 21, 2016 Halfords paint is good. I used red oxide and chassis black on the underside, tho on top of the old paint. Still there 5 years later. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted June 21, 2016 Share Posted June 21, 2016 Pete, While mine was out I gave it a really good clean, fitted new end plates from YRM because the old ones were a bit scruffy and corroded, then spend a bit of time sticking Flashband on the underside of it. Once it is in place, I go over it lightly with a hot air gun which softens the adhesive. I use one of those narrow (2" wide?) wall paper rollers to really get it moulded into corners and any changes in profile. I also stick it onto the top surfaces, cutting out the holes for seat / handbrake bolts using a piece of copper pipe as a die. Looks quite smart in a gunmetal grey kind of way... it must make some difference to the noise but I can't really tell to be honest... I fitted a marine battery isolator on the front of the box (For 2 batteries - 1, 2, 1+2, off), an Anderson 175 Plug and the little tail that comes with a Ctek charger because I've bolted Mazda seats in and it takes a bit of effort to get to the batteries. YRM also do moulded corner pieces for the corners at the front of the box that get kicked on the way in/out. Excellent for hiding the edges if you fit carpet or something. I initially thought the fit could have been a bit better until I realised I'd fitted the wrong on, correct it and they are an excellent snug fit. Quote Link to comment Share on other sites More sharing options...
