Tobias Press Posted November 27, 2016 Share Posted November 27, 2016 Hi I need to replace my release bearing so im gonna do the clutch at the same time as it has done nearly 110K. i have been trying to find the correct size for both the friction disc and the pressure plate which i believe is 235mm for the friction disc and 242mm for the pressure plate. however when i look on euro car parts 2 clutches come up (both valeo) one has the sizes which i have just said and the other has a larger friction disc but it says it is heavy duty. I was wondering if i can fit the larger (heavy duty) one or should i go for the smaller one. advise would be great. Thanks in advance Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2016 Share Posted November 27, 2016 heavy duty clutch for 200 & 300tdi engines is --- pressure cover LR part URB100760 friction plate was FTC1994 now UQB000130 [this has 8 damper springs, the standard plate has 6 springs] I have both on my 200tdi/stumpy R380 combination. 1 Quote Link to comment Share on other sites More sharing options...
Litch Posted November 27, 2016 Share Posted November 27, 2016 If you are interested I have a Valeo 130 friction plate, pressure plate and HD metal-sleeved release bearing that I took out of my 300TDi 90. I had done a rebuild of the clutch while I was fitting my galvanised bulkhead (made sense with all that room) and fitted all HD components but then shortly afterwards decided to change to auto so these parts came out again. Wouldn’t normally offer used clutch parts for sale but these have covered only 5K miles since new and are in perfect condition. Quote Link to comment Share on other sites More sharing options...
Joe90 Posted January 21, 2017 Share Posted January 21, 2017 Did you sell the clutch and will it fit the lt77 box ? Quote Link to comment Share on other sites More sharing options...
Litch Posted January 22, 2017 Share Posted January 22, 2017 Still in the garage. For R380, if they are the same then AOK. Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2017 Share Posted January 22, 2017 10 minutes ago, Litch said: Still in the garage. For R380, if they are the same then AOK. the part numbers in my original reply fit 200tdi & 300tdi with either LT77 or R380 gearboxes. Quote Link to comment Share on other sites More sharing options...
