02jcole Posted August 24, 2011 Share Posted August 24, 2011 I'm in the process of installing TD5 gauges, a MUD console and generally tidying up the wiring of my 1997 defender 90. I'm having difficulty sourcing two connectors which I require, I've tried all the usual suspects that I buy electrical components from (VWP, polevolt, autosparks,Rs, etc) but I've had no luck. The two connectors that I require are: 2 x pink plugs used in the back of the TD5 speedo, they look similar to an ISO plug used for wiring in a car stereo but the TD5 one is 10 pin not like the standard 8 pin ISO plug and it has a yellow bar to lock the terminals in to the plug. I also require a male and female connector for wiring in the master light switch as a previous owner has chopped the connectors off and soldered the wires together The light switch and connector can be seen in my link below. Light switch James Quote Link to comment Share on other sites More sharing options...
PaulMc Posted August 24, 2011 Share Posted August 24, 2011 I'm in the process of installing TD5 gauges, a MUD console and generally tidying up the wiring of my 1997 defender 90. I'm having difficulty sourcing two connectors which I require, I've tried all the usual suspects that I buy electrical components from (VWP, polevolt, autosparks,Rs, etc) but I've had no luck. The two connectors that I require are: 2 x pink plugs used in the back of the TD5 speedo, they look similar to an ISO plug used for wiring in a car stereo but the TD5 one is 10 pin not like the standard 8 pin ISO plug and it has a yellow bar to lock the terminals in to the plug. I also require a male and female connector for wiring in the master light switch as a previous owner has chopped the connectors off and soldered the wires together The light switch and connector can be seen in my link below. Light switch James The two 10-way ISO connectors can be bought here - http://www.nexxia.co.uk/products.asp?section=CAR%20AUDIO&category=ISO%20Connectors Connector shells and terminals are sold separately - Male Accessory ISO Housing An 10 way Accessory ISO block used for Accessory ISO connections such as CD Changers and displays. Requires M-55 terminals. Part Code: M-53-1 (£2.50 inc VAT) Car Radio connector ISO receptacles. ISO Receptacle that can be used with M-53-1 above. Wires can be crimpled into these receptacles and these clip into the housings. Supplied as a pack of 10 - Part Code: M-55-1 (£2.50 inc VAT) Supplied as a pack of 100 - Part Code: M-55 (£15.95 inc VAT) The OE Land Rover light switch connector is made by Sumitomo - . A similar 4-way connector can be bought here - http://www.kojaycat.com/Motorcycle%20connector%204%20way.htm 4 Way Tang Less Connector (4W-CNA-NAT) Natural coloured connector is supplied complete with male & female terminals . It has 8 terminals at 6.3mm 4W-CNA-NAT - £5.85 +VAT BUT... The light switch connector doesn't need to be identical to the Land Rover (Sumitomo) one and could be replaced by any 4-way connector with 6.3mm terminals for a lot less than the one from KojayCat. This one from Polevolt would do - Ref: MC4KIT Multiple connector kit 4 way Supplied with 5 female and 5 male terminals. Price each: (9 or fewer items) £0.80 (£0.96 Including VAT at 20%) . Quote Link to comment Share on other sites More sharing options...
02jcole Posted August 25, 2011 Author Share Posted August 25, 2011 Thank you very much for your excellent and speedy reply paul Do you know where I could possibly source the Sumitomo OE connector from as I would like to keep the connector standard to aid replacement of the switch in the future. I don't mind paying more to get the correct connector, but I suspect it may only be availble in large quantities! James Quote Link to comment Share on other sites More sharing options...
PaulMc Posted August 25, 2011 Share Posted August 25, 2011 Thank you very much for your excellent and speedy reply paul Do you know where I could possibly source the Sumitomo OE connector from as I would like to keep the connector standard to aid replacement of the switch in the future. I don't mind paying more to get the correct connector, but I suspect it may only be availble in large quantities! James Sorry, I don't know of anywhere selling them individually If you could get hold a used one cut out of a loom, then new compatible terminals are available from a couple of sources. If you know anyone with a Discovery II, then the Rear Fog Lamp Towing Cut Out Kit STC50181 uses the same connector, which is Land Rover part number - AFU3855 (not available as a spare part ) On the vehicle, an AFU3855 connector with a couple of loops of cable is removed from the rear loom and replaced with one with a relay which cuts the vehicles rear fog lights when a trailer with fog lights is plugged into the 12N connector. The AFU3855 connector with the cable loops is thrown away. STC50181 showing the AFU3855 connector - I saw the kits at Billing a couple of years ago, Mailorder 4x4 (I think ) had stacks of them for around £7.00 I wish I'd bought one at the time for my DII, as they're now nearly £40 Although, there is this one on eBay for a bit less - Discovery 2 Fog Light Cut Off Switch Towing STC50181 . Quote Link to comment Share on other sites More sharing options...
