Rear diff play - how much is too much?
Gentlemen-
I recently removed my rear prop shaft to remove the diff cover for some painting, etc.  Once I removed the rear prop I found that there was some noticeable play on the flange coming out of the rear diff. I could move it back and forth a good 10 degrees. This was not the UJs on the prop shaft, the prop shaft was removed.  So my questions is how much play should there be in the rear diff at the flange which connects to the rear prop?
