rover14 Posted June 13, 2017 Share Posted June 13, 2017 hello there i have defender td4 2010 and i have an issue with my gauges,when im reving all the gauges on cluster drops down and thwn goes up and some times it just wont move at all no rpm no rev whats the problem? Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted June 13, 2017 Share Posted June 13, 2017 Check the alternator belt is tight and not slipping, I had problems of a similar nature and that was the cause. May not be in your case, but rule out that to start with. Quote Link to comment Share on other sites More sharing options...
rover14 Posted June 13, 2017 Author Share Posted June 13, 2017 Just now, Jocklandjohn said: Check the alternator belt is tight and not slipping, I had problems of a similar nature and that was the cause. May not be in your case, but rule out that to start with. thanks for answer i check the belt is all good any more ideal? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 13, 2017 Share Posted June 13, 2017 Could be a shonky earth, it's often the case when more than one thing is affected. Check the earth straps (engine to chassis, chassis to battery, wiring loom to bulkhead, etc.). You can prove suspect ones by bridging them with a jump lead, if things get better with the jump lead that's your suspect. Quote Link to comment Share on other sites More sharing options...
