jad Posted August 1, 2017 Share Posted August 1, 2017 Hi, Can anyone tell me the function of these parts? Can they safely be shortened to move the bolt closer to the spring? Thanks Jad Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 1, 2017 Share Posted August 1, 2017 It keeps the leafs aligned and yes, you can shorten it. Shortening could conceivably reduce droop flexibility (when the weight is on the opposite side and you are cross-axling), but since leaf sprung Rovers have check straps and dampers that don't extend much further than the check straps allow (the straps are to prevent damper damage from over extension), in reality you won't see any change in spring flex. Quote Link to comment Share on other sites More sharing options...
jad Posted August 1, 2017 Author Share Posted August 1, 2017 Thanks snagger have shortened it a bit ? Quote Link to comment Share on other sites More sharing options...
mingdiesel Posted August 3, 2017 Share Posted August 3, 2017 Are they called "French Clip" or something? i drilled mine to put bolt & tube just above spring, seems ok. Quote Link to comment Share on other sites More sharing options...
jad Posted August 4, 2017 Author Share Posted August 4, 2017 Do you have any pictures Ming? Quote Link to comment Share on other sites More sharing options...
