Defender TD5 Swivel Balls - Part Numbers
Boris113
The swivels in my 2005 non-ABS Td5 110 are not in a good way, there's virtually no preload and minor corrosion on the balls. I'm going to rebuild both swivels with new balls, seals and bearings over Christmas. In the shed I have a set of swivel balls with part no's FRC7065 / FTC5366 that I purchased for the rebuild of a non-ABS 300tdi Discovery axle which has subsequently been mothballed. can anyone confirm if they are suitable for the 110? The numbers I've found on the web suggest various different ones.
Thanks, Harry
