Farcombehall Posted December 30, 2017 Share Posted December 30, 2017 Hi ived got defender 2.4 puma 90. theres slack in diff but in overrun there is a bad noise by gear stick sounds like dry bearing once throttle opened up again it stops anyone had this befor it’s done 60000 cheers Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted December 30, 2017 Share Posted December 30, 2017 Remove a propshaft and drive it in diff lock. If the noise doesn't go then run it with just the other prop. Check the UJs for play whilst they're off. This will tell you if it's front or back axle, or not Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 30, 2017 Share Posted December 30, 2017 Sample the rear diff oil,I've seen several not get to 24,000m before they fail.The oil is a giveaway, if its silvery in colour then the diff is shot. Quote Link to comment Share on other sites More sharing options...
Lightning Posted January 1, 2018 Share Posted January 1, 2018 Are the diffs not the same at the earlier ones, such as TD5? Quote Link to comment Share on other sites More sharing options...
