stobbie 10 Posted March 3, 2018 Share Posted March 3, 2018 (edited) Hi, I have a defender 2.4 TDCI. A few days ago it cut out while driving. It would immidiately start again en run for a short while. Sometimes for 30 seconds, sometimes 10. Now it won't fire at all. It cranks fine, but will not fire. It's freezing here, minus 8 degrees celcius. I thought there may be ice in the fuel filter so I have changed that, but it made no difference. I did have a few alarm problems lately, but at this moment it locks and unlocks fine with the keyfob and there is no immobiliser light on the dash. On my nanocom and on my IIDTool I see RPM's while cranking, so I assume my crankshaft position sensor is working. I've checked all underseat relays, they are all fine. Half of the times my IIDtool an nanocom looses contact with the car. When I disconnect the battery most of the times it will connect again. I was thinking of some kind of immobiliser problem. But should it crank when immobilised? I do have some errors about lost communication with instrument cluster, but when I clear them they will stay away for a while, but still no start. I have no diesel at the injectors. Should I always have diesel at the injectors? Even when I have some kind of electrical problem? The high pressure fuel pump is pure mechanical? Or can the VCV valve or something shut of all fuel to the rail? I don't see any railpressure on the display but when I record live values it shows a pressure.. With easy start the engine fires right up, but ofcourse dies again when I stop spraying. Any ideas? Edited March 3, 2018 by stobbie Quote Link to post Share on other sites
Scotts90 192 Posted March 4, 2018 Share Posted March 4, 2018 Can you hear the fuel pump prime on turning the ignition on? Quote Link to post Share on other sites
Brae Smithy 0 Posted March 28, 2020 Share Posted March 28, 2020 I realise this post was from 2 years ago but did you get to the bottom of this problem? I am having very similar symptoms and can't find a solution. Its starts, but each time it does, it runs for less time until after a few goes, it just stops immediately. Very little diesel coming through at the injectors although there is pressure registering on the live data. Hopefully you'll be able to help! Quote Link to post Share on other sites
