Part number's please
I’ve transferred the screw and olive bit over to the 300 tube. The tube fits in just the same and the length seem the same - so my plan was to benefit from the better fit and double check the reading by pouring in a precise amount of oil.
Are right ok i will need to get the screw in and olive part then
I did also consider using the series set up from the 2.25 - which I think is the same part as used on the 200tdi Defender engine - but I wasn’t sure how it would fit with the manifold.
There is a cheap one on eBay: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F253413495722
Looks like it should probably fit as it’s shorter and self supporting ..
Yeah it is very tight and i think it would break before it bends enough i've got the Def 200 one to try and its to tight
