Kevritchie Posted May 10, 2018 Share Posted May 10, 2018 Hi Guys, Looking for some guidance on starting issue. Its always started on the first turn off the key until about 2 weeks ago where it took about 5 minutes to get her going.Then yesterday I had the same issue ( on both occasions I did get her fired into life. However today no such luck ( battery now on charge due to excess starting lol. I have changed the fuel filter but still no success. Any suggestions would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted May 10, 2018 Share Posted May 10, 2018 If 90..remove the drivers seat baseand check the fuel pipes at the top of the tank. Not unheard of for them to corrode and end up with pin holes. Which leads to sucking air not fuel..... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 10, 2018 Share Posted May 10, 2018 Leak-off lines on injectors too, leaks there will result in poor starting as the fuel drains back. Quote Link to comment Share on other sites More sharing options...
Kevritchie Posted May 11, 2018 Author Share Posted May 11, 2018 Ok thanks guys , Will give those a check this morning 👍 Quote Link to comment Share on other sites More sharing options...
