Romeo Posted July 31, 2018 Share Posted July 31, 2018 While i drive my car goes into limp mode and only two injectors operate the car drives perfectly for about 20km and all of a sudden the engine just turns off. Is this a ecu problem or can you guys advise what it possibly can be Quote Link to comment Share on other sites More sharing options...
joe1 Posted August 11, 2018 Share Posted August 11, 2018 Just saw your post - sorry you didnt get any answers earlier - probably because its a bit of a well worn subject - if you've not already found the answers its probably good to start with the ecu injector loom and let oil drain from it etc - best to replace it if its in that oily state - and it wouldnt go amiss to take ecu out and let that drain overnight as well - hopefully it will just be the loom you need. Good luckĀ Quote Link to comment Share on other sites More sharing options...
