Johnmatt Posted February 1, 2019 Share Posted February 1, 2019 Please can someone help I bought my first range rover a m reg p38 I was told the the air compressor had gone as would pump up so changed for new one but it still doesn't pump up any help very much appreciated Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted February 1, 2019 Share Posted February 1, 2019 What are the symptoms (apart from won't pump up)? Is the pump running at all? Peter Quote Link to comment Share on other sites More sharing options...
Escape Posted February 4, 2019 Share Posted February 4, 2019 If the pump is running, remove the exhaust damper and check there is no air escaping. If there is, the diaphragm valve is leaking and needs to be replaced. It will dump all the compressed air before it can reach the tank. Filip Quote Link to comment Share on other sites More sharing options...
