Sloppy gearchange
David125
Check the plastic bushings & clips on the gear change mechanism, they can wear and fall out of the linkage and then it slops around. You can see it moving on the gearbox end with the bonnet open, or laying under the car for the gearstick end. You'll need a helper to waggle the stick :ph34r:
  • 3 weeks later...
