peter deer Posted December 24, 2006 Share Posted December 24, 2006 Hi 300 tdi /160 000 miles obviously developing a few leaks One I would like to stop is coming from the air pump that activates the break depression bell the leak is not at the pump/engine junction ,but in the head itself this head seems to be riveted is is possible to repair/seal ? if not ,is this expensive ? thanks for your advice and...Happy XMAS to you all Peter Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 24, 2006 Share Posted December 24, 2006 Hi 300 tdi /160 000 miles obviously developing a few leaks One I would like to stop is coming from the air pump that activates the break depression bell the leak is not at the pump/engine junction ,but in the head itself this head seems to be riveted is is possible to repair/seal ? if not ,is this expensive ? thanks for your advice and...Happy XMAS to you all Peter There are no internal parts available for this from LR, I know that, whether anybody recons them I don't know. Personally at that age I'd sling it and put a new one on, lucky its lasted (if the original which it may not be) as the 300Tdi vacuum pumps are not reknowned for a long and happy life! Can't recall if the servo unit is the same on a Disco or not (I think maybe not) but the brake servo on 300Tdi Defenders is a regular failure, they crack around the bolt holes on the front of the servo can, we change loads of them at work, symptoms are a loss of brake vacuum, can be hardly noticeable except under emergency braking which is not a good time to find out... or the brakes can be as bad as if the engine was off. Quote Link to comment Share on other sites More sharing options...
peter deer Posted December 26, 2006 Author Share Posted December 26, 2006 There are no internal parts available for this from LR, I know that, whether anybody recons them I don't know. Personally at that age I'd sling it and put a new one on, lucky its lasted (if the original which it may not be) as the 300Tdi vacuum pumps are not reknowned for a long and happy life!Can't recall if the servo unit is the same on a Disco or not (I think maybe not) but the brake servo on 300Tdi Defenders is a regular failure, they crack around the bolt holes on the front of the servo can, we change loads of them at work, symptoms are a loss of brake vacuum, can be hardly noticeable except under emergency braking which is not a good time to find out... or the brakes can be as bad as if the engine was off. Many thanks for your reply ,it is good to know you are not the only one in that situation You must be spot on ,there must be small cracks that let the oil seep when these crack widen ,i'll loose the braking power Ill be ordering a new pump tomorrow!! many thanks again and ..Happy New Year peter Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 26, 2006 Share Posted December 26, 2006 I'm talking about the servo can on the master cylinder that cracks, not the pump, but I don't mess with anything in a braking system, I change it! Quote Link to comment Share on other sites More sharing options...
peter deer Posted December 29, 2006 Author Share Posted December 29, 2006 I'm talking about the servo can on the master cylinder that cracks, not the pump, but I don't mess with anything in a braking system, I change it! Vacuum pump ordered today should arrive Tuesday many thanks Peter Quote Link to comment Share on other sites More sharing options...
