Quagmire Posted August 7, 2019 Share Posted August 7, 2019 Hi guys, Thought i'd post here as not only is the LT77 something us LR owners are familiar with, but I know a lot of you don't own just LR products and are also into other BL derived things too. I have a Rover 3500s, and the original 4 speed has recently come to the end of its life, i thought i would take the opportunity to fit a 5 speed from an SD1. I've had this LT77 sat on the floor of the garage for a few years now, and when I bought it I thought I had checked all gears selected but obviously not...😡 Last night I setup the shifter mechanism properly, which meant that reverse is now easier to select. On turning the box I get a graunchy/rattling noise when in reverse, sounds almost like two gears contacting each other or something. All other gears sound smooth and engage perfectly fine. if i've done this right there should a link below to a (bad) video I took last night: LT77 reverse noise Any ideas on what it might be would be appreciated! My next step is to clear out the garage, build a workbench to get the thing on and have a look inside. Thats going to take a while though, so any suggestions people have would at least give me a path to go down when I get to that point. Cheers Quote Link to comment Share on other sites More sharing options...
rtbarton Posted August 7, 2019 Share Posted August 7, 2019 Selector fork loose on its shaft, worn/broken fork, detent problem, broken gear tooth. Can you make the noise go away by pulling/pushing the gear lever beyond where it normally detents? If setting it up properly gives the noise, it sounds like it has been maladjusted in the past to hide the problem. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 7, 2019 Author Share Posted August 7, 2019 Good thinking! I wonder if I removed the shifter mech and tried to manipulate it manually whether it would still sound the same? Something to try for sure. thanks Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 7, 2019 Author Share Posted August 7, 2019 uodate- Took the shifter mech off and had a fiddle about shifting directly, still the same... Arse. Quote Link to comment Share on other sites More sharing options...
