Chicken Drumstick Posted October 30, 2019 Share Posted October 30, 2019 3 hours ago, Northern Paul said: Once again, thanks for the updates and experiences. Just to clarify - if I go down the spacer route they will being fitted behind steel wheels. Presumably hub centric ones (like I referenced in my first post) are what I am after? Cheers, Paul Steel wheels are nut centric, i.e. they centre on the wheel nuts which are beveled. You want plain spacers for these ideally. As the centre hole in the steel rims varies from make to make. And they may be a tight fit on a hub centric wheel spacer. Alloy wheels however sit on the hub and centre on it, the wheel nuts are flat and simply hold the wheel on, rather than centre it. 1 Quote Link to comment Share on other sites More sharing options...
