Marc.be Posted November 6, 2019 Share Posted November 6, 2019 Hi, I converted the vm engine in a range rover to a 200tdi. I used the vm gearbox with the tdi bellhousing, a homemade spigot bushing, and original 200tdi clutch. Problem is that I can't shift my gears, not even when pumping. When I put a gear and start the engine,I can stand still, so clutch is disengaged but not fully... Does anyone has an idea why it isn't working? Kind regards, Marc Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted November 7, 2019 Share Posted November 7, 2019 It could be your clutch release isn't pushing in far enough to fully disengage the friction plate, or, the input is binding on the spigot bush as it warms up. Quote Link to comment Share on other sites More sharing options...
Marc.be Posted November 8, 2019 Author Share Posted November 8, 2019 Hi, I think the problem is that the clutch isn't released far enough. Is there any other way than changing the excentric on the clutch pédal? Marc Quote Link to comment Share on other sites More sharing options...
