Acko 0 Posted December 7, 2019 Share Posted December 7, 2019 Any I dear what this is when you driving last about 3 or 4 seconds then goes off Quote Link to post Share on other sites
FridgeFreezer 2,075 Posted December 7, 2019 Share Posted December 7, 2019 You mean the ABS light? Quote Link to post Share on other sites
Patrick Morgan 1 Posted December 7, 2019 Share Posted December 7, 2019 Yeah, had me guessing when it came up on the phone, FridgeFreezer ! So, we'll go with 'Why does my ABS light come on?' ABS warning lights are usually associated with road-wheel sensors and reluctor-rings that make 'em work. Get it scanned- my AUTEL (not the most expensive scanner) tells you what wheel- which takes out the guesswork. Quote Link to post Share on other sites
Acko 0 Posted December 7, 2019 Author Share Posted December 7, 2019 Abs light,parking light comes on while you driving losses power to rev count speedo counter also power to temp gauge all go off Quote Link to post Share on other sites
FridgeFreezer 2,075 Posted December 8, 2019 Share Posted December 8, 2019 12 hours ago, Acko said: Abs light,parking light comes on while you driving losses power to rev count speedo counter also power to temp gauge all go off Sounds a lot like a bad earth if more than one thing is affected. Is your battery secure & connections solid? Also, little hint for you - posting with the title "Freelander td4" in the Freelander forum doesn't help people see what your problem is and means you're less likely to get answers - we can already guess it's a Freelander! 1 Quote Link to post Share on other sites
