3 door disco seat issue
enen
Hi
Just a heads up to any 3 door disco owners
The drivers seat was a bit "loose". I found the pivot shaft welds had broken from the seat frame and the bushings had seized up. The checked the passenger seat and found the welds had also broken but bushings hadnt seized yet.
I welded them up with bigger beads.
I find the whole thing is a bit 'lightweight' in the engineering and the paint (leading to premature corrosion), I am on the lookout for seats from something else that will be a bit of an upgrade;...  mine are in my RRC........... if I had the originals from the RR I might consider rebuilding/re-upholstering but I think something more modern might be easier to source?
