Evening,
The indicators failed this evening. They were fine on the outward journey but once the battery isolator was turned back on and the ignition turned on the trailer light on the dash illuminated and neither the hazards or indicators work. With the ignition off, turning on the hazards just illuminated the trailer light continuously on the dash. The actual lights do not flash. I have LED lights all round except the side repeaters.
any ideas?
Yep old style relay fitted and lights worked but as expected too fast, so changed all four lamps back to original until I could source a replacement flasher. Then of course I started tinkering with something else and while digging around on the bench found a spare LED flasher unit, so all change back to LEDS again! Must get a spare flasher and keep it in the cubby box.
