daveturnbull Posted April 30, 2020 Share Posted April 30, 2020 Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2020 Share Posted April 30, 2020 looking at my wiring diagram & going on the colours, Brown/white [NW] White/black [WB] Green [G] White [W] is the feed for heated rear screen & rear wash/wiper when fitted. Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2020 Share Posted April 30, 2020 It would plug into item 7 on the rear heated screen & rear wash/wipe sub loom. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted April 30, 2020 Author Share Posted April 30, 2020 Thanks Ralph. I've not got any of that fitted so will tape it up out of the way. I was hoping that the white wire would be an ignition live so I could use it for something else, but testing reveals 0 volts. Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2020 Share Posted April 30, 2020 Strange because White & the Green wires are meant to be ignition switched, following it on the wiring diagram takes me to the fusebox at fuse number 16 a 5amp fuse, then other side of that fuse runs up a green wire to the same plug. check for power on the brown/white wire. which goes to fuse 17 then back up the black/white wire to the same lug. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted April 30, 2020 Author Share Posted April 30, 2020 I'll check the other pins tomorrow. I imagined the white would be as it a female, the others are all male. I guess it could be that there is another sub-loom I don't have on the inside that runs up to various switches, which provides the power by a 2 wires into one feedback loop. They seem to like doing that on these looms. It would be safer that way too if the option was not fitted - no unconnected live wires floating around in the engine bay. Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2020 Share Posted April 30, 2020 Yes they sub loom in the diagram above has the switches, 2 fuses & the VSS wiring. page 714, item 4 is the sub loom & associated parts http://www.retroanaconda.com/landrover/parts_books/110/8_body_electrics_p667-740.pdf Quote Link to comment Share on other sites More sharing options...
