Eddie_V8 Posted May 10, 2020 Share Posted May 10, 2020 (edited) Hi all, I'm currently going through a megasquirt build on my 110, changing the cracked 3.9 to a 4.0 GEMS. I've got as far as getting her started but the timing is not right. I had thought I had got it close before I bolted everything together but it's very lumpy running, backfiring etc. When I set TDC I used #1 and the rocker cover off, spun the engine waiting for both valves to fully close etc. My question is is there a more accurate way of timing the 4.0 as there are no pulley marks (cheers landrover). Any help much appreciated. Ed Edited May 10, 2020 by Eddie_V8 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 10, 2020 Share Posted May 10, 2020 Here you go: Bear in mind you may have your leads in the wrong place, it is the #1 most common fault with backfiring and lumpy running. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted May 10, 2020 Share Posted May 10, 2020 I had the 4.6 with a GEMS and changed to a front mounted toothed wheel behind the crankshaft pulley. I timed it by using the gap on the timing ring on the flywheel. Ran as sweet as a nut! Cheers Peter Quote Link to comment Share on other sites More sharing options...
Eddie_V8 Posted May 10, 2020 Author Share Posted May 10, 2020 Cheers Bowie69, will give that a try. Peter, I've swapped from a 3.9 to the 4.0, the 3.9 had a flywheel like the 3.5 with no trigger ring pickup. The new engine didn't have a fly wheel with it. Quote Link to comment Share on other sites More sharing options...
