Dave. Posted May 31, 2020 Share Posted May 31, 2020 Hi I’m after the b post c post and sills for my 1998 110 CSW has anyone had any experience with the Brit part side frames? Part no DA4780 DA4787 the genuine as crazy expensive or any other manufacturers? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 31, 2020 Share Posted May 31, 2020 YRM do assembled galvanised side frames for 110SW https://yrmit.co.uk/product/lhs-complete-side-frame-assembly-assembled-lr-defender-series-4-5-door-2/ https://yrmit.co.uk/product/lhs-complete-side-frame-assembly-assembled-lr-defender-series-4-5-door/ on my 110CSW a few years ago, a friend & myself made some new lower channels using 50mm x 30mm x 3mm rectangular box we retained the original B posts & repair the lower part of the angled C posts. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted June 1, 2020 Share Posted June 1, 2020 As Ralph says ive just done mine using yrm..I read up on it first and avoided others due to bad fitting stories. All bits I’ve got from yrm are superb... they just fit perfectly might be worth stripping down first, as with all things defender that one little job turns into several others. I got the little corner plates for end of 2nd row seat box, 2nd row heel board, both footwells and other little bits oh, and don’t forget the little square seal thingys that go with your posts. think it’s these https://yrmit.co.uk/product/2nd-row-seat-support-to-chassis-bracket-2007-onwards-rubber-gasket-lr-defender-2/ last of all tigerseal or alternative. Quote Link to comment Share on other sites More sharing options...
