rear safari door handle central locking
Hi all,
regarding a late 300tdi 90 (VA132...)
It is supposed to have door handle 395037 as far as I understand.
We intend to install central locking in the future and I was looking at handle FUB500060 which is supposed to fit 2A... which has central door locking mechanism.
Anybody knows if it will physically fit the door of the 300tdi?
The electrics for the central locking I assume I will figure out eventually, short term it is just to get it fitted with a normal barrel for key.
Thanks
Tobias
I think it will fit, but it's down to the lock type, is the present lock - do you use the ignition key for the lock or is it a smaller half size key? The early locks are 7pin tumbler (short key) - later handles the lock is the longer 14pin tumbler. The lock barrels aren't interchangeable.
