V8 4,0 Motronic misfiring
tychoS
DII 2002 V8 4,0 Motronic
When pushing the engine to perform, it misfires badly.
Eg. when trying to accelerate briskly from 100 to 130 km/h, the engine will most often misfire, loose its will to accelerate, and only reach say 115 km/h. When cruising at 110 km/h it will sometimes start to misfire and the speed drops down to 100 or 95 km/h. At other times it will happily drive at 110 or 130 km/h for quite a while without misfiring.
Replaced during 2020 by myself: camshaft(LR), hydraulic lifters(LR), timing chain(LR) + sprockets, injectors (Bosch), sparkplugs(NGK)
The camshaft was well past its prime, as were the other parts. Replacing all these parts took the engine from undriveable to working ok, unless I push it above say 75% or so. I did the replacements in increments, and each increment made the engine perform significantly better/less badly.
So whats likely to be the next step? I could keep on replacing parts, the next step would be either the ignition coils+leads or the lambda+maf sensors.
But I am wondering if the problem could be elsewhere, eg. either the ECU itself or the wiring harness for it.
How to best diagnose?
Nanocom has this sorry story to tell:
P0134 = LAMBDA SENSOR UPSTREAM
CATALYST BANK 1 DRIVE CYCLE C
OCCURED 21 TIMES
SIGNAL INVALID
P0172 = MIXTURE ADAPTION FACTOR FRA
OCCURED 1 TIMES
SIGNAL TOO HIGH
P0175 = MIXTURE ADAPTION FACTOR
FRA BANK 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
P0300 = EMISSION RELEVANT MISFIRE
MULTIPLE CYLINDERS DRIVE CYCLE C
OCCURED 2 TIMES
SIGNAL TOO HIGH
P0303 = CATALYST DAMAGING MISFIRE
CYL 3 DRIVE CYCLE C
OCCURED 64 TIMES
SIGNAL TOO HIGH
P0305 = CATALYST DAMAGING MISFIRE
CYL 5 DRIVE CYCLE C
OCCURED 64 TIMES
SIGNAL TOO HIGH
P1000 = EMISSION RELEVANT MISFIRE
CYLINDER 2 DRIVE CYCLE C
OCCURED 2 TIMES
SIGNAL TOO HIGH
P1000 = LAMBDA SENSOR UPSTREAM
CATALYST BANK 2 DRIVE CYCLE C
OCCURED 7 TIMES
SIGNAL INVALID
P1300 = CATALYST DAMAGING MISFIRE
OCCURED 66 TIMES
SIGNAL TOO HIGH
P1668 = ANTI-THEFT ALARM SERIAL
LINK FAULT DRIVE CYCLE A
OCCURED 1 TIMES
SIGNAL TOO HIGH
NA
OCCURED 65 TIMES
SIGNAL TOO LOW
FAULT IS CURRENTLY PRESENT
NA
OCCURED 193 TIMES
SIGNAL TOO LOW
NA
OCCURED 0 TIMES
SIGNAL TOO LOW
Edited by tychoS
