reb78 Posted January 28, 2021 Share Posted January 28, 2021 Its a 1989 110. The other night I was out and noticed the faintest glow from the brake warning light. On my 110, this is triggered by the PDWA valve on the bulkhead. The light is very softly glowing all of the time. You wouldnt even see it in the daylight. I am going to clean the connections up but can anyone think of anything else? Do the PDWA valves go faulty? This one is original. Its braking fine etc. With a leak or pressure difference, the light would only come on when using the brake (had this before due to a slight weep from a rear cylinder) but this is faintly glowing all of the time so pretty sure its not a leak or functional problem more electrical/earthing? Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2021 Share Posted January 28, 2021 moisture in/on the connections which live at bottom of the switch. same year/switch as my 110. Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 28, 2021 Author Share Posted January 28, 2021 Thanks Ralph. I hope thats all it is. The only replacements out there seem to be Britpart and not keen on any of their parts near my braking system! Hopefully its just as you say. I will clean it up at the weekend. Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2021 Share Posted January 28, 2021 Hope its that easy, could even be a chaffed wire. Quote Link to comment Share on other sites More sharing options...
