Brian B Posted February 10, 2021 Share Posted February 10, 2021 I have no power to headlight switch on 94 Defender 90 with diesel Can anyone tell me where the power comes from? There is no under hood fuse box like US models have. Quote Link to comment Share on other sites More sharing options...
steve b Posted February 10, 2021 Share Posted February 10, 2021 Welcome to the forum Brian , The inference from your post would suggest no side lights either ? Can you check with a meter the feed to the switch to eliminate switch issues ? cheers Steve b Quote Link to comment Share on other sites More sharing options...
monkie Posted February 10, 2021 Share Posted February 10, 2021 I have made this basic circuit diagram for the lighting circuit on my 1988 110. You need to work backwards to find where your issue is. The brown wire to the switch is the unfused live feed for the entire circuit which comes from the main bus on the starter motor solenoid terminal. It provides the feed at the light switch for the entire circuit. The fuses as you can see in my diagram protect the side lights, dipped beam and main beam between the lights and the switches. Quote Link to comment Share on other sites More sharing options...
jasonb-no Posted March 16, 2021 Share Posted March 16, 2021 I had the same issue on my 1999 Td5 several years ago. Turned out to be burnt «Header 0287» More info about the issue here Quote Link to comment Share on other sites More sharing options...
