no power to headlight switch on 94 Defender 90 with diesel
I have made this basic circuit diagram for the lighting circuit on my 1988 110. You need to work backwards to find where your issue is. The brown wire to the switch is the unfused live feed for the entire circuit which comes from the main bus on the starter motor solenoid terminal. It provides the feed at the light switch for the entire circuit. The fuses as you can see in my diagram protect the side lights, dipped beam and main beam between the lights and the switches.
  • 1 month later...
