monkie Posted November 13, 2021 Share Posted November 13, 2021 I've fitted an R380 stumpy to a defender 200tdi engine in my 110. I used the slave cylinder pushrod that came with the stumpy box (it was shorter than the pushrod from my LT77. All works fine except it feels like the biting point is not right. I have to push the pedal almost all the way down to get the clutch to disengage, the biting point seems very low to me. I'm wondering if the pushrod might be too short? Quote Link to comment Share on other sites More sharing options...
western Posted November 13, 2021 Share Posted November 13, 2021 Mine has pushrod FTC4229, slave cylinder 591231 & release bearing UTJ100210, The LT77 release bearing is about 10mm to long, set the pedal height as in workshop manual [& in the tech archive index] 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted November 13, 2021 Author Share Posted November 13, 2021 Thanks Ralph. I did check the release bearing against my old one... As you say the one for the stumpy was shorter than the one from my LT77. I will double check the adjustment tomorrow in the light. 1 Quote Link to comment Share on other sites More sharing options...
