Les Brock Posted January 20, 2007 Share Posted January 20, 2007 As in I'm having a mental blockage....... Can't remember where they connect....seem to remember it goes to ground via the mounting fixing then the lead goes to the output feed to the battery.....but for the life of me I can't remember..... Seem to also remember the Disco alternaotr had two fitted where did the other one go......W terminal ? It's an age thing Quote Link to comment Share on other sites More sharing options...
Les Brock Posted January 21, 2007 Author Share Posted January 21, 2007 ok....so its not just me then Quote Link to comment Share on other sites More sharing options...
simonb Posted January 22, 2007 Share Posted January 22, 2007 As in I'm having a mental blockage.......Can't remember where they connect....seem to remember it goes to ground via the mounting fixing then the lead goes to the output feed to the battery.....but for the life of me I can't remember..... Seem to also remember the Disco alternaotr had two fitted where did the other one go......W terminal ? It's an age thing Between big (output) terminal and case - doesn't matter which way round for the connections -usually tag is earthed. May have another one on the warning light terminal. Not normally fitted to W terminal as that is ac not dc. Quote Link to comment Share on other sites More sharing options...
