Mad85 Posted February 16, 2022 Share Posted February 16, 2022 I would like to wire a Carling Switch so it acts as a winch isolator. I already have a suitably big 400amp relay, but how do I wire the carling switch so that it only works with the ignition on? Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted February 16, 2022 Share Posted February 16, 2022 3 hours ago, Mad85 said: I would like to wire a Carling Switch so it acts as a winch isolator. I already have a suitably big 400amp relay, but how do I wire the carling switch so that it only works with the ignition on? Ignition live feed to the switch feed 400amp may not be enough - nost winches will run to 450, even 500amps before stall Quote Link to comment Share on other sites More sharing options...
Mad85 Posted February 18, 2022 Author Share Posted February 18, 2022 thanks, checked again and the isolator is actually 500a! its a Rhino Carbon winch, it is rated to up to 400amp but as you say better to have a bit more Quote Link to comment Share on other sites More sharing options...
