garrycol Posted January 24, 2007 Share Posted January 24, 2007 Does anyone have a Freelander with a lift. I would like to discuss options - I am in Canberra - Australia. The max spring/spacer lift is 2" (because of the short front driveshafts) and I have not found any body lifts (like the 2" body lift on a subaru). My investigations have thrown up 4 options. 1. DAP type steel spacers on top of the suspension towers gives a full 2" but the cost is about $390 US plus postage etc. ($600AUD) 2. A 38mm plastic spacer system from the US is $300AUD landed in Australia but doesn't give the full 2" but is easier to install and no changes to brake lines are needed. 3. Bigger springs - Kings Springs (Aust) makes 35mm longer springs that sag to 30mm springs ($340AUD) - I would like a bit bigger lift but new shockies are not needed. Ironman (Aust) also make springs but I cannot find any details on these. 4.A guy in the UK has sent me some cad drawings of a system that replaces the suspension towers bolts with much longer ones and and you use nuts on the bolts to provide the lift - I know it works but I think registration and other authorities might have problems with this so I am not going this route. I have recently put 225/70 R16 BFG ATs on and this gives me about an inch but I want to finish the job - clearance under a standard freelander is 195mm under the engine which is effectively reduced because of the front independent suspension - with both front wheels depressed clearance is zip. So if anyone has done a lift I would like to hear about any issues you have uncovered. Thanks Gazzz Quote Link to comment Share on other sites More sharing options...
21j Posted January 26, 2007 Share Posted January 26, 2007 I'm going to do one by "Celtic4x4". If you look at site "MADfreelanders" they use them. Quote Link to comment Share on other sites More sharing options...
jules Posted February 17, 2007 Share Posted February 17, 2007 Bearmach do a 2" lift kit off the shelf. Quote Link to comment Share on other sites More sharing options...
