Tom L Posted July 14, 2022 Share Posted July 14, 2022 I'm wondering if anyone could help me (as a first timer to using this forum). It is some time since i removed the old tank from the old chassis and i am not sure i have got the fixing rubbers located correctly on the front fuel tank mounting bolt. all of the diagrams seem to suggest this is how it should go, but the tank does not seem to sit right in this position. any advise would be gratefully received as i've wasted hours trying unsuccessfully to google an image. Tom Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 15, 2022 Share Posted July 15, 2022 That how I would of mounted the rubbers, but it does seem a little high. How tight is the bolt, does it pull down a bit if you wind it up a bit more? Mike Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 15, 2022 Share Posted July 15, 2022 The back end of the tank looks very close to the chassis, is it touching at all? With ~50 ltr of fuel in the tank it will settle down, try loosed the chassis bolts and it might settle a little lower too. Quote Link to comment Share on other sites More sharing options...
