ukspike Posted August 29, 2022 Share Posted August 29, 2022 Can anyone tell me please how to get to the bulb that illuminates the clock in the centre of the dash mines not glowing in the dark Quote Link to comment Share on other sites More sharing options...
Badger110 Posted September 1, 2022 Share Posted September 1, 2022 Undo the top 2 hex bolts to remove the top cover, then the 2 at the front. the clocks are held on by 2 long bolts into the subframe, undo these and lift the clock unit up and out, removing the connector. The bulbs are removable from the rear of the cluster after you remove the cover by prising the clips holding it on Quote Link to comment Share on other sites More sharing options...
