JohnnoK Posted May 19, 2023 Share Posted May 19, 2023 On 5/16/2023 at 9:33 AM, Northwards said: ^ That’s like a ‘chicken and egg’ thing. The point of sourcing the pump is to try and improve oil feed to an overdrive bearing - and the overdrive is mounted into the PTO slot. Unless I’ve completely missed something obvious in what you’ve said, which is always possible! I get that the bearing is there, but I was saying that you might be able to use the rear end of the shaft to DRIVE the pump to supply that (and the other bearings if desired) with suitable modifications to the rear cover to house the pump and the shaft to drive the pump. Quote Link to comment Share on other sites More sharing options...
